Hello since the update I have a font that I can’t change. Which configuration file needs to be changed manually? Is it the one in /etc/conf “local.conf”? Or there is another way. Thank you
Can you describe your problem in more detail?
Hello, the font on my xperia 10 III is no longer the same.I had changed it when I had installed another keyboard of another language. After the update to 4.6013 I can’t change the font in the phone’s settings you can only change the size.I think you can do it by modifying the configuration file by connecting
While it’s maybe cannons to shoot a sparrow I recommend looking ad @dumol ’s work here:
dumol:master ← dumol:hidpi
opened 09:24AM - 20 Nov 23 UTC
This adds a PixelPerfect FontConfig setup geared towards high DPI displays such … as modern laptops, tablets, and smartphones.
If you are using a low DPI device (less than 120 dpi) stick to the master branch for now, as more configuring is needed to test this branch in such a scenario. (Improvements are coming your way too, be patient.)
**How to test**:
1. Make sure you move aside whatever you have in `~/.config/fontconfig` and `~/.local/share/fonts` (These do not exist by default in any OS that I know.)
2. Download and unpack in `$HOME` the PixelPerfect-hidpi-0.4beta2.tar.gz released archive:
cd ~
curl -LO https://github.com/dumol/PixelPerfect/releases/download/v0.4.0beta2/PixelPerfect-hidpi-0.4beta2.tar.gz
tar xvfz PixelPerfect-hidpi-0.4beta2.tar.gz
3. If using a desktop environment, configure your device to use **_System-ui_** or **_Asap_** for the interface text and **_ui-monospace_** or _**Cascadia Code PL SemiLight**_ for monospace text (these should be identical). E.g., for GNOME, use the commands added to the README through 06bfc73e. (You can use `ui-monospace` for the second command, but beware the monospace option won't show up properly in the GNOME Tweaks app.)
4. Log out and in again to fully propagate the changed settings.
5. If you use Flatpak and/or Snap apps, run the instructions added to the README through 06bfc73e.
6. If you use Sailfish OS, you should also change `theme_pixel_ratio` to `1.5` (it's usually `1.75`) to take advantage of the improved Fontconfig setup, as detailed at https://forum.sailfishos.org/t/ui-themer-missing-from-openrepos/2457/89. Then you can also set **_Asap_** as UI font (falling back to **_Roboto_** and _**Arimo**_) in `~/.config/fontconfig/os/sfos.conf` instead of **_Barlow_** and its fallbacks. Also, in Settings->Display->Text Size, "normal" is now actually "small", and you have to set "large" to get "normal" text sizes. The only known downside to this change of theme pixel ratio: the “diallers” in the Phone app and the locked screens looking a bit more cramped than they should.
Check out https://reeddesign.co.uk/test/webfonts.html to see the improvements. Many other web pages should benefit from this setup, including GitHub's web interface here. You can even disable loading remote fonts in your browser, but please report any sites not looking good afterwards.
Do let me know your thoughts on this, thanks!
Instead of step 2, you can also do this:
* Clone this repo and check out this branch, then symlink the resulting directory as `~/.config/fontconfig`.
* Download the relevant pre-release 0.4beta2 tarballs from https://github.com/dumol/PixelPerfect/releases/tag/v0.4.0beta2. Those would be the `common*` and `hidpi*` packages. However, the `common-hacks` archive is only needed if you block remote fonts in your browser.
* Unpack those tarballs to `~/.local/share/fonts`.
The right place to edit is ~/.config/fontconfig , not /etc.
HTH!
Hi thansk a lot it works
Bye
