Is anyone interested in Cellular (GSM/UMTS/LTE) protocol logging with Sailfish OS?
As you may or may not know, the Qualcomm debug interface is well-enough reverse-engineered so that it can be convinced to spit out protocol logs for what your device is doing on the network.
Without a project or a specific issue to troubleshoot, this is not something i can really get motivated to spend a lot of time on. But perhaps someone else has a really killer use-case for this…
There are at least two options to make this happen, QCSuper and scat, but neither quite works out of the box with SailfishOS.
I have some hacks here to get QCSuper working at all, but it isn’t particularly pretty:
Actual protocol decoding and analysis is done in Wireshark. I got the impression that the decoding there isn’t perfect, but it is quite good. Or maybe QCSuper is tripping it up, i don’t know.
