I’m using this SFDK version 3.9.6 (Stable).
I’m compiling Whisperfish locally using this command (at the time of writing, please pull this commit instead of master):
sfdk -c target=SailfishOS-4.4.0.58-aarch64 build -- --with shareplugin_v2 --with lto
For convenience, I removed the path prefix /home/matti/SailfishOS/mersdk/targets/SailfishOS-4.4.0.58-aarch64.default from all outputs below.
I then see the following output:
/[...]/opt/cross/bin/aarch64-meego-linux-gnu-strip: '/home/deploy/installroot/usr/bin/harbour-whisperfish,': No such file
/[...]/opt/cross/bin/aarch64-meego-linux-gnu-strip: 'too': No such file
/[...]/opt/cross/bin/aarch64-meego-linux-gnu-strip: 'many': No such file
/[...]/opt/cross/bin/aarch64-meego-linux-gnu-strip: 'notes': No such file
/[...]/opt/cross/bin/aarch64-meego-linux-gnu-strip: '(256)': No such file
After some searching, I found this bug report: find-debuginfo.sh fails on ELF with more than 256 notes. It has a link to a commit that fixes that: Fix stripping of binaries for changed file output. After installing vim and editing these three files to contain the changes in the commit, I now get these lines instead:
+ /[...]/usr/lib/rpm/meego/brp-strip /usr/bin/strip
/[...]/opt/cross/bin/aarch64-meego-linux-gnu-strip: warning: /home/deploy/installroot/usr/bin/harbour-whisperfish: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000000
(repeat the line above for hundreds of times)
+ /[...]/usr/lib/rpm/meego/brp-strip-static-archive /usr/bin/strip
As far as I know, the warning message is benign, and can be ignored here. Now the resulting binary is 5.1MB instead of 25MB, so the stripping process works.
For completeness; I edited these three files inside build-shell
/home/matti/SailfishOS/mersdk/targets/SailfishOS-4.4.0.58-aarch64.default/usr/lib/rpm/meego/brp-strip
/home/matti/SailfishOS/mersdk/targets/SailfishOS-4.4.0.58-aarch64.default/usr/lib/rpm/meego/brp-strip-comment-note
/home/matti/SailfishOS/mersdk/targets/SailfishOS-4.4.0.58-aarch64.default/usr/lib/rpm/meego/brp-strip-shared
making this change
- sed -n -e 's/^\(.*\):[ ]*ELF.*, not stripped/\1/p'`; do
+ sed -n -e 's/^\(.*\):[ ]*ELF.*, not stripped.*/\1/p'`; do
which fixed the issue. Athough this was triggered by a Rust application, it can happen to C/C++ applications, too.
Please include the commit or update rpm to newer version.
Thanks!
It comes from this repository
