Can't flash Sony Xperia 10 V
This is a Windows flashing script for Sony Xperia 10 V device.
Power on the device in fastboot mode, by doing the following:
  1. Turn off your Xperia.
  2. Connect one end of a USB cable to your PC.
  3. While holding the volume up button pressed, connect the other end of
    the USB cable to your Xperia.
  4. After this you should see the blue LED lit on Xperia, and it will be
    ready for flashing
Presione una tecla para continuar . . .
Verifying MD5 checksums…
MD5SUM ‘ed5a809dc0024d83cbab4fb9933d598d’ match for file ‘AdbWinApi.dll’.
MD5SUM ‘0e24119daf1909e398fa1850b6112077’ match for file ‘AdbWinUsbApi.dll’.
MD5SUM ‘b84cf5d3dc1747787281ff0d2c31d2ae’ match for file ‘fastboot.exe’.
MD5SUM ‘b5954704c9bae8e8c72bbf511ae2201a’ match for file ‘flash-on-windows.bat’.
Searching for a compatible device…
The device is unlocked for the flashing process. Continuing…
Found ‘SW_binaries_for_Xperia_Android_14_5.4_v3a_zambezi.img’ that will be used as vendor image. Continuing…
C:\Users\serko\Downloads\Sailfish_OS-Jolla-4.6.0.15-xqdc54-1.0.0.25\Sailfish_OS-Jolla-4.6.0.15-xqdc54-1.0.0.25>fastboot.exe -s HQ6384008D reboot fastboot
Rebooting into fastboot OKAY [ 0.003s]
< waiting for HQ6384008D >
https://forum.sailfishos.org/t/problems-to-flash-sailfish-on-xperia-10-iv-fastbootd-menu/20063/7
should be in the instructions …
