REPRODUCIBILITY: permanently
BUILD ID: Sailfish OS 3.3.0.16 (Rokua)
HARDWARE: Xperia 10, dual SIM
UI LANGUAGE: English (US)
REGRESSION: No
When trying to place a call it won’t be initiated. Audio is not played: no alarms, no media.
Issue appeared after OS crashed, after ending a WhatsApp call and starting a normal call.
- not clear
Being able to place and receive calls. Having audio working.
No ability to place or receive calls. No audio in general.
Reboot doesn’t help.
Running pkcon install pulseaudio and then reboot the phone doesn’t help.
Here the response from systemctl status pulseaudio.
[root@Xperia10-DualSIM nemo]# systemctl status pulseaudio -l
â pulseaudio.service - PulseAudio (system-wide mode)
Loaded: loaded (/usr/lib/systemd/system/pulseaudio.service; static; vendor preset: enabled)
Active: failed (Result: signal) since Sat 2020-08-08 07:56:18 CEST; 14min ago
Process: 5047 ExecStopPost=/bin/sh -c rm -f /run/pulse/pid (code=exited, status=0/SUCCESS)
Process: 2985 ExecStart=/usr/bin/pulseaudio --daemonize=no --system --disallow-module-loading $CONFIG (code=killed, signal=SEGV)
Main PID: 2985 (code=killed, signal=SEGV)
Aug 08 07:54:43 Xperia10-DualSIM pulseaudio[2985]: E: [pulseaudio] dbusif.c: Got 2 routing decisions. 2 decisions were incomplete.
Aug 08 07:56:16 Xperia10-DualSIM pulseaudio[2985]: E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.AccessDenied: Rejected send message, 2 matched rules; type="method_call", sender=":1.8" (uid=171 pid=2985 comm="/usr/bin/pulseaudio --daemonize=no --system --disa" label="u:r:kernel:s0") interface="org.freedesktop.DBus.ObjectManager" member="GetManagedObjects" error name="(unset)" requested_reply="0" destination="org.bluez" (uid=0 pid=4815 comm="/usr/libexec/bluetooth/bluetoothd -n" label="u:r:kernel:s0")
Aug 08 07:56:16 Xperia10-DualSIM pulseaudio[2985]: E: [pulseaudio] bluez4-util.c: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.AccessDenied: Rejected send message, 2 matched rules; type="method_call", sender=":1.8" (uid=171 pid=2985 comm="/usr/bin/pulseaudio --daemonize=no --system --disa" label="u:r:kernel:s0") interface="org.bluez.Manager" member="GetProperties" error name="(unset)" requested_reply="0" destination="org.bluez" (uid=0 pid=4815 comm="/usr/libexec/bluetooth/bluetoothd -n" label="u:r:kernel:s0")
Aug 08 07:56:17 Xperia10-DualSIM pulseaudio[2985]: W: [pulseaudio] protocol-native.c: Denied access to client with invalid authentication data.
Aug 08 07:56:18 Xperia10-DualSIM systemd[1]: Stopping PulseAudio (system-wide mode)...
Aug 08 07:56:18 Xperia10-DualSIM systemd[1]: pulseaudio.service: Main process exited, code=killed, status=11/SEGV
Aug 08 07:56:18 Xperia10-DualSIM systemd[1]: Stopped PulseAudio (system-wide mode).
Aug 08 07:56:18 Xperia10-DualSIM systemd[1]: pulseaudio.service: Unit entered failed state.
Aug 08 07:56:18 Xperia10-DualSIM systemd[1]: pulseaudio.service: Failed with result 'signal'.
Aug 08 07:58:43 Xperia10-DualSIM systemd[1]: Stopped PulseAudio (system-wide mode).
