REPRODUCIBILITY: 98 %
OS VERSION: 4.4.0.64
HARDWARE: XA2 and 10 III
UI LANGUAGE: german
REGRESSION:
Location services can’t be enabled.
Try to enable location settings. It’s poosible to go into that settings, make them active/enabled, but when you leave settings App or just the location settings sub page and then go back into the location setting these ar still disabled. As result the phone get’s no location data.
IO have this problem an XA2 and on 10 III…
- Enable location settings.
- leave subpage or setting app.
- Go back to settings app-> location
After enabing location service/making the active the phone should store these settings.
Every hange made in location settings is lost wehn you leave the location setings page, leaving the cations services inactive.
Android support, MicroG.
After I freshly flashed the 10 III this function worked, but is gone now. I have no idea what may cause this problems, but it’s something I had on XA2 already since SFOS 4.0. I was happy that this GPS problems where gone with 10 III, but as they show up again on this device too I don’t know what to do…
