I’ve a Jolla C thanks to Coderus who gave to me as a gift. Thank you
Anyway each time you do a factory reset it returns to 4.0.1 and you have to do 5/6 system updates that takes hours to do.
Can you flash directly Sauna on it?
Can Jolla update the base for the Jolla C so when you reset it, the default version would be like 4.5?
Thank you
Hi,
I don’t know whether CODeRUS sfos-builder is still functional https://github.com/CODeRUS/sfos-builder. Unfortunately for me it always failed at this point which was beyond my limited skill set https://talk.maemo.org/showpost.php?p=1574418&postcount=87
Maybe you should stop doing that?
I will try myself. My main distro is Arch, but I can run older Ubuntu/Debian in container/VM and try there
Did you tried then?
Thank you for your replies
Here are the images I got. Use AT YOUR OWN RISK.
Edit: I just tried 4.6.0.11 image on my Jolla C and it worked just nice!
Anyway, hmm can I ask you how to use this?
I’ll try this now, thank you so @WunderWungiel
I’ll go directly to 4.6.0.11
edit: I saw in the screenshot that you started doing this from 4.3, so I can’t flash this over the stock 4.0.1 right?
You can, I flashed 4.6.0.11 over 2.0, this was just test.
Here is list of commands for Jolla C:
Quite a jump
anyway, how do I access to fastboot on the Jolla C?
It’s the recovery that you can obtain pressing vol and power button?
Power off, hold Vol Down and connect to PC
I succeed! Thank you so much!
If you flash this via fastboot, that will flash over the default recovery image that you can revert by doing a factory reset?
A question: using the script, you could get back to SFOS 2 for example?
If you manage to build Sailfish OS 2 image, definitely possible. I can try.
And yes, it overwrites recovery.
Please try it!! I want to go back in time ahahah
I understand, Jolla C working perfectly even after a lot of different flashes
Thanks for sharing this! You’ve really saved me as I’ve just used the SFOS 4.6 image to re-flash my almost dead Jolla C. Cheers!
