Is there anyone that knows if the flashtool and xperifirm can do the same work than EMMA to reinstall Sony android in a sony device with sailfishos?
yes, and with more options. There’s also Newflasher,([TOOL] Newflasher (xperia command line flasher) | XDA Forums)… Depending on your end goal, Emma might be best, (if you’re simply wanting to install factory firmware); it auto-detects model, region, etc., and downloads and installs appropriate latest version. The others are better if you want something specific, like a different update version, or a specific region, or just certain partitions, etc
My goal is to try to get back to factory firmware using Linux instead of windows.
Flashtool/Xperifirm will do…
I am trying to flash my x10 II back to sony, but I cant succed. Dyou know how and where could I get help here? thanks
I had to use 0.9.28 version instead .34 to make it work
