@flypig i got logs, as I understandit they may contain private data. How do we handle them? Can i annonymize them ( they contain hex data dumps), or upload them where they are not publicly available?
Thanks for the report @thigg, and for providing the abridged logs. And sorry for not replying to your earlier message about it.
I’ve created an internal bug report and added your logs to it. I’ve also tagged this as tracked. If there are updates on this in future I’ll do my best to post them here.
@thigg: we discussed this internally and @slava looking looked through your logs. Unfortunately we’re not able to reproduce it. From what you say in the bug report you can reproduce this reliably; would you mind please collecting some more logs for us during the period in which the crash occurs?
The following will output details from your historical log containing relevant keywords, so would be something to run directly after a crash to pick up any details:
If you could collect some output from one of these and share the logs with us (again, ensuring first that there’s no sensitive data in there), then it would be really appreciated and hopefully helpful.
I sent you the logs. I tried to reproduce it today with another friend and everything worked normally. However I can reproduce this with friends that are using AldiTalk/Telefonica.
If you need more i saved the whole journal, that should contain everything
Thanks for sending me the logs @thigg. Hopefully what you provided will be enough to diagnose the issue, but if not, I’ll get back to you to request the full set of logs. Thanks for going to this trouble.
