OSVERSION: 5.0.0.21
HARDWARE: Reeder S19 Max Pro S - s19mps - s19mps - 1.0.0.15 - aarch64
REGRESSION: not specified
Don’t know whether the HW should be capable of doing this, but the front/selfie camera can not focus on objects closer than ~30cm from the camera
Using stock Browser, Camera permissions granted for that website.
The use case is trying to register a new SIM at Crif FPI Assistant
The process involves taking a pic of some ID card, and the site uses the selfie camera for that.
While the face is fine wrt. focus, trying to get the card to scan does not work as it is always out of focus. If it is in focus, (beside your face), it is too small to be registered.
But really, to reproduce, try to focus on anything closer to the camera than your face.
EXPECTED RESULTS:
Selfie camera should focus.
ACTUAL RESULTS:
- Patchmanager: yes
- OpenRepos: yes
- Chum: yes
- Other: none specified
Actually, forget that use case mentioned above. I tried with a Laptop, and it has the same issue. That site’s process is just stupid in that it doesn’t let you upload a picture.
Device Owner User: nemo
Home Encryption: enabled
