REPRODUCIBILITY:
OS VERSION:5.0.0.70
HARDWARE:
UI LANGUAGE:PL
REGRESSION:
GPS in android apps like waze
I have no signal, pure maps works, but I`m from Poland so this app is not usefull for me.
REPRODUCIBILITY:
OS VERSION:5.0.0.70
HARDWARE:
UI LANGUAGE:PL
REGRESSION:
No clue why Pure maps wouldn’t work in Poland. Did you try OSM Scout server or any other map provider?
Pure Maps show map, but it think that I am in Finland:rofl:![]()
so it’s useless. I would be happy if google maps work. I get Jolla C2 phone for free ( yes, woman give me phone, because they thinked that is android lol). I will try use tutorial to flash gapps
Where does GPS info puts you?
I was ( maps thinked) 5531km away from my home🤣
I mean app “GPS Info” or even CSD. I think it’s important to see raw values first.
First, I play with Gapps, then try solution
I have no problem with Pure Maps and also live in Poland.
Looks like you have got no GPS fix either due to missing permission or maybe wrong settings. Google won’t help then.
Activate Location and allow Pure Maps access to your location data.
Install gpsinfo and run it in parallel
As soon as you see some satellites in use in gpsinfo, puremaps should show propper location
And yes, go outside
No ja właśnie mam, ale najbardziej dziwo mnie że, waze nie ma dostępu do GPS
