OSVERSION: 5.0.0.43
HARDWARE: Reeder S19 Max Pro S - s19mps - s19mps - 1.0.0.30 - aarch64
UI LANGUAGE: Deutsch (user: de_DE, os: de_DE.utf8)
REGRESSION: not tested before
When connecting a wireless Keyboard with Touchpad (Logitech K400r) to Jolla C2 USB-C via its USB-Dongle, the Mouse Axis are only correct on Portrait-Mode, in Landscape-Mode the Axis are interchanged (horizontal = vertical and vertical = horizontal). It doesnt matter if i Plugin the USB-Dongle in Landscape-Mode, same behaviour.
Wireless Keyboard with Touchpad (Mouse-Support like Logitech K400r) with USB-Dongle, a USB-C to USB-A-Adapter.
Plugin USB-Donge of Wireless Keyboard with USB-C-Adapter to Jolla C2
Move Mouse in Landscape-Mode
Axis are interchanged.
EXPECTED RESULTS:
Mouse-Axis are the same on Portrait/Landscape-Mode.
ACTUAL RESULTS:
Mouse-Axis are interchanged in Landscape-Mode.
Patchmanager: yes
OpenRepos: yes
Chum: yes
Other: none specified
Home Encryption: enabled
Orientation is set to automatic
Rotating homescreen is enabled
the initial version of this bug report was created using Bugger 0.9.13+git2
So I have been trying this on the Fairphone 5 and same issues here.
Steps I took>
Identified the mouse I was using running via SSH in su mode> ls -l /dev/input/by-id and found the only event8 named usb-413c-3010-event-mouse → ../event8
So i have created a file to test the potential fixes, but none of these worked in the following location> /etc/udev/rules.99/ folder
Created a new file 99-mouse-rotation.rules, added the information to rotate the mouse by 90/180/270/0 degrees (only 1 option can be uncommented at a time).
Then run> udevadm hwdb –update
But none of these worked. However the mouse cursor is correct in both portrait and landscape only the movement is the issue in landscape mode.
Would be keen to know if I am on the right track here to workaround this issue to find a workable solution for all.
I am using the Fairphone 5 and have Sailfish Build 5.0.0.68 installed.
Tested with a USB-C to USB-A adapter or Deltaco USB-C adapter along with a Logitech M185 mouse.
Note: The only alternative out of the box fix for now is to physically rotate the mouse left 90 degress and it kinda works albeit a bit odd.
