OSVERSION: 5.0.0.29
HARDWARE: Reeder S19 Max Pro S - s19mps - s19mps - 1.0.0.22 - aarch64
REGRESSION: yes (since: 4.4.0.72 - aarch64)
Now, this may actually be notabug/an improvement/by design re. security, but it is an regression and it breaks some monitoring tools.
None?
Here’s one way, but you can see it without collectd:
- install collectd
- start the service
- monitor the service output with
systemctl --user status -l collectd
EXPECTED RESULTS:
It’s actually not unexpected, but on XPeria10iii, debufgfs is mounted as:
nemo@PGXperiiia10:~ $ ls -l /sys/kernel/debug -add
drwxr-xr-x 96 root root 0 Nov 20 05:00 /sys/kernel/debug/
while on the C2 it’s
nemo@PGJollaC2:~ $ ls -l /sys/kernel/debug -ad
drwx------ 96 root root 0 Jan 1 1970 /sys/kernel/debug/
ACTUAL RESULTS:
Some plugins of collectd rely on debugfs files to be accessible:
Nov 20 08:01:18 PGJollaC2 systemd[2369]: Started Collectd statistics daemon.
Nov 20 08:01:18 PGJollaC2 collectd[48157]: [2024-11-20 08:01:18] radio plugin: Found 3 radios
Nov 20 08:01:18 PGJollaC2 collectd[48157]: [2024-11-20 08:01:18] suspend plugin: cannot read /sys/kernel/debug/suspend_stats,
unregistered plugin
Nov 20 08:01:18 PGJollaC2 collectd[48157]: [2024-11-20 08:01:18] Initialization complete, entering read-loop.
Nov 20 08:01:18 PGJollaC2 collectd[48157]: [2024-11-20 08:01:18] radio: cannot read value from /sys/class/rfkill/rfkill0/type
Nov 20 08:01:18 PGJollaC2 collectd[48157]: [2024-11-20 08:01:18] read-function of plugin `radio' failed. Will suspend it for 3
00.000 seconds.
- Patchmanager: yes
- OpenRepos: yes
- Chum: yes
- Other: none specified
Device Owner User: nemo
Home Encryption: enabled
mandatory: xkcd: Workflow
the initial version of this bug report was created using Bugger 0.9.11+git2
