Hello all,
today I got the C2. I started the phone after unpacking an put the cable into to charging the battery. OS starts - but the cable was not fixed in the device and the process was stopped with questions for country.
After vull caharging the battery, I started the phone oncemore, but the istallation process stopped with country question.
What can I do?
Thank you for info
Hello,
Use search, you are not the first i fear.
else read the jolla c2 threads.
I did not see a quick solution yet.
thx for info. Hopefully a solution will be found otherwise Saifish is out of every race
Try to add a USB mice to your C2 and use it to bypass the touch screen failure.
thx, It was possible with mouse in blind work. I entered the code 6 digits,date and time Wifi skipped and then … nothing. I started oncemore - touch screen was eneabled. I entered the code and it turns, turns, turns…
Bad luck
I wonder if nobody from jolla can really comment on all the problems we are currently having with the C2.
