[C2] Camera-App: Zoomfactor-Setting stays same between Main-/Selfie-Cam
OSVERSION: 5.0.0.43
HARDWARE: Reeder S19 Max Pro S - s19mps - s19mps - 1.0.0.30 - aarch64
UI LANGUAGE: Deutsch (user: de_DE, os: de_DE.utf8)
REGRESSION: not specified
Zoomfactor-Setting is shared between Main-/Selfie-Cam
  1. Open Camera-App
  2. Use Main-Lens (1.0)
  3. Zoom in
  4. Change to Selfie-Cam
  5. Selfie-Cam is zoomed in like the Main-Lens Setting
EXPECTED RESULTS:
Selfie-Cam zoom is resetted or has own Zoom-Settings
ACTUAL RESULTS:
Selfie-Cam take the Zoomfactor from the Main-Cam
  • Patchmanager: yes
  • OpenRepos: yes
  • Chum: yes
  • Other: none specified
Bug is also vice-versa (Main-Cam takes the Zoomfactor from Selfie-Cam)
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.11+git2
Indeed. Let’s keep the zoom levels separate on back and front cameras.
It still happen in SailfishOS Version 5.0.0.70 on Jolla C2.
