C2 battery gone while updated?
OSVERSION: 5.0.0.76
HARDWARE: Reeder S19 Max Pro S - s19mps - s19mps - 1.0.0.59 - aarch64
UI LANGUAGE: Suomi (user: fi_FI, os: fi_FI.utf8)
REGRESSION: yes (since: 5.0.0.5 - n/a)
Nothing with charging/discharging is working properly. Battery Buddy(marvellous app!) shows charging of ~200-500mA no matter what. Battery indicator is not decreasing while using phone, until it shuts down from 100% in 30 minute to complete zero. While writing this report, this phone is not charging over 18% I know C2 has battery problems but CSD says battery health is good. And I wanted to know about Battery Buddy log charger control file not found! Should there be charger control?’
Everything was working before 5.0.0.76 update
1.plug charger
2.any charger
3. In house or car
EXPECTED RESULTS:
ACTUAL RESULTS:
  • Patchmanager: no
  • OpenRepos: yes
  • Chum: yes
  • Other: none specified
[23:29:34] harbour-batterybuddy-daemon 4.3.2-1
[23:29:34] Using /home/defaultuser/.config/harbour-batterybuddy/harbour-batterybuddy.conf
[23:29:34] Load: lowAlert 20
[23:29:34] Load: highAlert 90
[23:29:34] Load: highNotificationsInterval 13
[23:29:34] Load: lowNotificationsInterval 13
[23:29:34] Load: healthNotificationsInterval 13
[23:29:34] Load: limitEnabled 0
[23:29:34] Load: lowLimit 70
[23:29:34] Load: highLimit 85
[23:29:34] Load: logLevel 0
[23:29:34] Log level set to low
[23:29:34] Battery charge file: /sys/class/power_supply/battery/capacity
[23:29:34] Charging/discharging current file: /sys/class/power_supply/battery/current_now
[23:29:34] Max charge current file: not found
[23:29:34] Status file: /sys/class/power_supply/battery/status
[23:29:34] Charger status file: not found
[23:29:34] AC status file: not found
[23:29:34] Battery temperature file: /sys/class/power_supply/battery/temp
[23:29:34] Battery health file: /sys/class/power_supply/battery/health
[23:29:34] Charger control file not found!
[23:29:34] Please contact the developer with your device model!
[23:29:34] Battery current inverted
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.10+git7
Since the upgrade my C2-phone to SailfishOS 5.0.0.76 last week, I also experienced some unusual battery drains in the morning:
When picking up the device for the first time after waking up, in -at least two times the last 5 days- it would suddenly sound a ‘low-battery” alarm.
First time I left it unplugged the when going to bed because it indicated the power level was higher than some 80%. The morning after the low-power alarm went off and it indicated a battery level of 8%. When plugging the power cord in, it also seemed to be siugnificanly warmer than the ambient temperature, but after a couple of hours the battery was recharged completely again.
Yesterday night I also left it unplugged with the battery at around 100%.
When I picked it up the first time this morning, it beeped loudly and shut down, showing a battery level of 2%.
Did not notice a higher temperature this time (but probably some power safe mechanism already killed any energy intensive process before it dropped down to 2%)
Since the phone powered off, I don’t have the logs before the last boot.
User: defaultuser
Encryption: (Also) enabled for both built-in system-flash and removable micro SD-card.
<Content of /home/defaultuser/.cache/harbour-batterybuddy-daemon.log>
[09:51:01] harbour-batterybuddy-daemon 4.3.2-1
[09:51:01] Using /home/defaultuser/.config/harbour-batterybuddy/harbour-batterybuddy.conf
[09:51:01] Load: highAlert 82
[09:51:01] Load: highNotificationsInterval 13
[09:51:01] Load: lowNotificationsInterval 13
[09:51:01] Load: healthNotificationsInterval 13
[09:51:01] Load: highLimit 80
[09:51:01] Battery charge file: /sys/class/power_supply/battery/capacity
[09:51:01] Charging/discharging current file: /sys/class/power_supply/battery/current_now
[09:51:01] Max charge current file: not found
[09:51:01] Status file: /sys/class/power_supply/battery/status
[09:51:01] Charger status file: not found
[09:51:01] AC status file: not found
[09:51:01] Battery temperature file: /sys/class/power_supply/battery/temp
[09:51:01] Battery health file: /sys/class/power_supply/battery/health
[09:51:01] Charger control file not found!
[09:51:01] Please contact the developer with your device model!
[09:51:01] Battery: 4%
[09:51:01] Battery current inverted
[09:51:01] State: charging
[09:51:01] Temperature: 34°C
[09:51:01] Health: good
[09:51:24] Temperature: 35°C
[09:51:54] Battery: 5%
[09:51:54] Temperature: 34°C
[09:52:24] Temperature: 32°C
[09:52:54] Temperature: 29°C
[09:53:24] Battery: 6%
</Content of /home/defaultuser/.cache/harbour-batterybuddy-daemon.log>
