C2: Android apps facing internet connection issues
Hi
I am observing a problems with Android apps to connect to internet. For example Telegram: when C2 is switched on, Telegram loads all chats correctly. But later it hangs in status “Connecting”. Sometimes helps to downgrade from 4G to 3G connection and to restart network connections. Similiar case is messenger: it loads initially fine, but later it doesn’t show pictures in the chat. And I have more such cases like that which prevents in daily use.
Is anybody familiar with that or can advise what to do? Many thanks,
Karoy79
I’d recommend you use the search. It’s widely known and reported, as well as acknowledged by Jolla as planned to be fixed, that most Android applications (those which use DNS rather than hardcoding in I.P. addresses) do not work when the C2 is on mobile data and not WiFi.
