[C2] Access regular home screen during backup restoration
OSVERSION: 5.0.0.29
HARDWARE: Reeder S19 Max Pro S - s19mps - s19mps - 1.0.0.22 - aarch64
UI LANGUAGE: Français (user: fr_FR, os: fr_FR.utf8)
REGRESSION: not specified
During backup restoration, the interface forbids to escape the restoration screen.
But, if you lock the screen and unlock by swiping from left to right you arrive to the events screen and after that you have access to everything else.
If you unlock from right to left, you arrive on the restoration screen as intended.
A backup is needed to restore it.
1.Restore a backup
2.Lock screen
3.Unlock by swiping from left to right
EXPECTED RESULTS:
Go back to restore screen after unlocking, independently of the swipe direction used to unlock.
ACTUAL RESULTS:
Events screen after unlock allowing to bypass the restoration screen.
  • Patchmanager: no
  • OpenRepos: yes
  • Chum: yes
  • Other: none specified
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.11+git2
