REPRODUCIBILITY: 100%
OS VERSION: 5.0.0.43
HARDWARE: Jolla C2
UI LANGUAGE: English (UK)
REGRESSION: -
When activating cellular connection, IPv6 default route is not set and therefore IPv6 traffic doesn’t work. Have to manually add it with ip -6 route add default dev seth_lte0 as root to make IPv6 routing to work.
Use SIM card: SIM1| DNA (Finland)
Roaming: Always allow
Data accces point (default): dna internet / internet, protocol Dual, authentication None
Network mode: Prefer 4G
Using “4G calling (VoLTE)” and “Select network automatically”.
Network show DNA.
- Disable all network connectiont (cellural + wifi) => no connection
- Activate only cellular connection
- Check that IPv6 doesn’t have default route and IPv6 doesn’t work
Expected to have default route set and have IPv6 working after cellural activation.
IPv6 doesn’t work.
None.
IPv6 routes without any connection:
[root@JollaC2 defaultuser]# ip -6 route
::1 dev lo proto kernel metric 256 pref medium
Cellular connected and IPv6 routes before adding the default route manually:
:: dev seth_lte0 metric 1 pref medium
2001:14b8:1000::1 dev seth_lte0 metric 1 onlink pref medium
2001:14b8:1000::2 dev seth_lte0 metric 1 onlink pref medium
2001:14bb:af:9372::/64 dev seth_lte0 proto kernel metric 256 pref medium
IPv6 connections failing:
[root@JollaC2 defaultuser]# ping6 www.google.fi
PING www.google.fi (2a00:1450:4026:808::2003): 56 data bytes
ping6: sendto: Network is unreachable
Adding route:
[root@JollaC2 defaultuser]# ip -6 route add default dev seth_lte0
Updated routes:
default dev seth_lte0 metric 1024 pref medium
Verifying that conection works:
64 bytes from 2a00:1450:4026:808::2003: seq=0 ttl=60 time=13.805 ms
64 bytes from 2a00:1450:4026:808::2003: seq=1 ttl=60 time=14.764 ms
Also tested same DNA/Finland SIM card with Jolla C 4.6.0.13 and it seems to have the same IPv6 problem. Had to manually add the route with ip -6 route add default dev rmnet_data0. Previously I’ve used Elisa and didn’t have problems.
