Bypass screen lock by using shortcuts when fingerprint sensor has lost fingerprints
REPRODUCIBILITY: When fingerprint sensor is unresponsive
OS VERSION: 4.4.0.64 (Vanha Rauma)
HARDWARE: Xperia 10ii
UI LANGUAGE: English & Finnish at least
REGRESSION: Not tested on other versions
When my fingerprint sensor once again for the n+1:th time lost my saved fingerprints, I found out that when using the optional shortcuts on top or when using gesture to get the camera open from the bottom, one can bypass the security code and access the device.
When I added a lost fingerprint back, the bypass no longer worked, so it seems to be related the situation when fingerprints are suddenly missing.
Fingerprint sensor being unresponsive and all previously given fingerprints are lost from the settings
CASE A)
  1. Wait for the fingerprint sensor to stop working once again
  2. Go to settings > lock screen > add shortcut > select application (for example clock)
  3. Allow the screen to lock itself and go dark
  4. Wake screen, do not unlock it
  5. swipe down to select the previously created shortcut
  6. swipe left > swipe up
  7. Phone is unlocked without fingerprint or code
CASE B)
  2. Go to settings > gestures > enable “quick access to camera”
  5. swipe up from the camera symbol to quick access camera
Phone asking for security code to unlock the phone
Phone is unlocked without asking security code
Settings → System → Display → Sleep after: was 2 minutes, then tried with 30 seconds with the same results
Settings → System → Device lock → Automatic locking → No Delay
Could you please add to “Additional information” few settings.
  • Settings → System → Display → Sleep after
  • Settings → System → Device lock → Automatic locking
Pondering if really locked as display turning off does not mean that device lock kicks in. Only if automatic locking “No delay” then device lock is activated right after display is dimmed.
Added the information requested to my original post.
