Path to connam configuration changed a little and is out of date on this site connman - Sailfish OS
Site states that patch to Connman config is /var/lib/connman/ but it’s
/home/defaultuser/.local/share/system/privileged/connman/
Xperia 10 / SFOS 4.2 / new flashed (“defaultuser”) -
My connman config is still at /etc/connman/main.conf . Did I miss something?
Probably /var/lib/connman/ are global settings but /home/defaultuser/.local/share/system/privileged/connman/ are user settings.
But it’s worth to mention that in documentation.
And where are your saved networks?
I suggest to mention that devices flashed with images before a certain date, have nemo instead of defaultuser… Even if one upgrades OTA…
@amaretzek you are right you and all my devices have nemo user instead of defaultuser.
I just want to show that documentation is out of date.
well actually non-user specific stuff should be in /home/.system/var/lib/connman nowadays .
No access to directory “privileged” as user “nemo” with file browser. Didn’t try now as “devel su”, but I’m shure, the saved networks will be there…
try devel-su -p, that gets you “privileged” but not root access.
