This bug has been already reported on together.jolla.com
| REPRODUCIBILITY: | 100% |
| BUILD ID = OS VERSION: | 4.1.0.23 |
| HARDWARE (XA2, Xperia 10…): | XA2 Plus |
| UI LANGUAGE: | Russian |
| REGRESSION: (compared to previous public release: Yes, No, ?): | Yes |
In the previous version, the fingerprint opened the main screen (desktop) in any of the cases:
1 when the device was automatically locked on timeout
2 when the screen is off but the device is not locked (the fingerprint wakes up the device, unlocks it and shows the main screen)
3 when the screen is on the lock-screen but the device is not locked (when you turn the screen off and on again or close and open the cover case and you can just swipe and view the main screen)
As of 4.1.0.23 the fingerprint does nothing for the third case!
In Settings->Device Lock set Automatic Locking to 5 min
Add few fingerprints to unlock
1 Turn on the device, you see the main screen
2 Turn off the screen with the power button or cover case
3 Turn on the screen immediately without waiting for the lock (few seconds after turning it off)
4 Try use the fingerprint to open the main screen
The main screen should be shown.
Nothing happens, the main screen is available only on swipe.
It is really annoying that you cannot open the main screen with a fingerprint if the device is not locked by timeout. As for previous releases, I just used the fingerprint to view the main screen in all cases
