Browser fails to display zvv.ch timetable
BUILD ID = OS VERSION (Settings > About product): 4.3.0.12
HARDWARE (XA2, X10, X10 II, …): Xperia X
UI LANGUAGE: German
REGRESSION: (compared to previous public release: Yes, No, ?): unknown
My local public transport provider has updated its website, and now I can’t use its online timetable using the stock browser. It will simply not load the results or even the start page for a timetable query.
  1. Open https://www.zvv.ch/ in the browser
  2. Enter departure station (For example “Zürich”) and destination station (For example “Winterthur”).
  3. Select “Verbindung suchen”.
The second way to use the timetable also fails:
  2. Select the “hamburger” menu on the top left, select “Timetable” → “Timetable”
  3. Browser shows a mostly white page with a header and a footer.
First case:
Timetable should get loaded and show actual connections.
Second case:
Timetable query should load and allow you to start your search.
Timetable doesn’t get loaded in both cases.
As workaround, it’s possible to use Fahrplan aarch64/Fahrplan and configure bahn.de instead of sbb.ch as backend. It works quite good.
sbb.ch backend has been modified and because Fahrplan is not maintained anymore, you have to use the German one.
Basically, yes, but Fahrplan using bahn.de has some limitations as it seems to uses the timetable as planed by the network.
zvv.ch has live traffic date, which can be a major advantage if buses are stuck in traffic during rush hour. If I have 5 minutes to transfer from the bus to a train, but the bus is 10 minutes late, it will take that into account.
Sailfish Browser is based on Firefox 60. The latest Android Firefox is 68 from July 2020 (it can load the search results page and seems to work from there). On the XA2 I have Firefox 97 Beta which is OK.
If you have Android Support, install Opera or Chrome (Opera Mini doesn’t work).
Else install Flatpak and Angelfish (mobile browser; works like Firefox 68 - the search page doesn’t accept input) and start with the search in the address (and bookmark your favorites):
I will consider your workarounds, but I still hope for a less outdated browser in Sailfish OS with a future release. From a security perspective, Firefox 60 doesn’t look good (I wouldn’t use it for sensitive applications like banking).
Even Debian managed to upgrade to the latest Firefox-ESR version in old-old-stable :slight_smile:
The next Sailfish OS release 4.4.0 will have the Gecko engine esr78.
The websites dicussed here will behave differently with it. :slight_smile:
This would definitely be a huge improvement. Not the current ESR, but almost there :slightly_smiling_face:
Thank you! Many modern web sites have serious issues with current browser (you simply cannot use https://www.vr.fi for example).
I cannot reproduce the reported problems with the Jolla C2 on 5.0.0.62.
Somebody else?
If not, let’s close this report.
I suppose it has been fixed with the browser update.
It works on my x10-ii, but I can’t easily insert a station. Letters doesn’t appears immediately.
Let’s keep it open, then. Perhaps it depends on the phone.
On XA2 with 5.0.0.62 it is the same. You have to press Enter after the first Letter of the Station. Then it will shown in the browser and you will see all following letters after typing.
For me, the website works ok on the C2 and 10 V. However, on 10 II it fails to show the typed letters. But if I tap the Backspace key first, then typing letters starts working.
It is similar on my side, works as expected on a C2, but needs the backspace hack on my 10 III. I don’t know if this is a software thing, or if my 10 III has some settings taken over by a restore from the previous device. The C2 has a fresh profile.
