Sony Xperia 10 III (Dual-Sim), SFOS 4.5.0.25
I reflashed the smartphone and wanted to close the bootloader. After I closed the bootloader via fastboot (with “fastboot oem lock”), I was able to start the device exactly once. After that, I received a system message that the system was corrupt and the device switched off again automatically after five seconds. This means that I no longer have any access to the smartphone.
Afterwards I tried to flash the smartphone again. Unfortunately, I didn’t write down the IMEI. However, I discovered that there are several numbers printed on the SIM card compartment that could be the IMEI.
So I started fastboot again and received a response via “fastboot devices” in the form “XX615X2X4X fastboot”. The smartphone is obviously recognised. However, if I now enter “fastboot oem unlock” and the assumed IMEI (15 digits), I get the error message “FAILED (remote: ‘Incorrect format for unlock data’)”.
What am I doing wrong? Does anyone know a way of finding out the IMEI or verifying the assumed one? What does the format look like? Or is there another way (with Linux) to get access to the bootloader/ the smartphone?
