legi
11 June 2021 12:15
1
Hi!
I have simple page with two rects:
code is
import QtQuick 2.0
import Sailfish.Silica 1.0
Page {
Rectangle {
color: "red"
x: 100
y: 100
width: 300
height: 150
border.color: "yellow"
border.width: 15
radius: 15
Rectangle {
color: "green"
x: 150
y: 150
width: 300
height: 150
border.color: "blue"
border.width: 15
radius: 15
opacity: 50
How I can set blur effect (semi-transparent) for green rect , like app drawer menu ?
karry
11 June 2021 12:48
2
Hi. You may use something like this:
import QtQuick 2.0
Page {
Rectangle {
color: "red"
x: 100
y: 100
width: 300
height: 150
border.width: 15
radius: 15
ShaderEffectSource {
x: greenBox.x
y: greenBox.z
width: greenBox.width
height: greenBox.height
sourceItem: page
recursive: true
live: true
sourceRect: Qt.rect(greenBox.x, greenBox.y, greenBox.width, greenBox.height)
Rectangle {
color: "green"
x: 150
y: 150
width: 300
height: 150
border.width: 15
radius: 15
opacity: 50
FastBlur {
anchors.fill: parent
source: blurSource
radius: 32
I donβt test this code, but using the same method here: osmscout-sailfish/MapPage.qml at master Β· Karry/osmscout-sailfish Β· GitHub
legi
11 June 2021 13:34
3
Thank you for link with sample, Iβll try it to investigate.
Your code sample is do animating (fade or recursive blur?) from normal colors to dark.
This is from start
and intermediate
and finish
also change y: greenBox.z to y: greenBox.y
karry
11 June 2021 15:09
4
ou, sorry. there is one mistake⦠sourceItem
have to be sibling component, not the parent one. in such case blured image is taken as a base for the blurring. It is creating such animation
I hope itβs not a stupid question but have you tried just setting opacity?
opacity: 0.6
for instance? The βblurβ is βthereβ anyway, or?
Hereβs one way. . . . .
import QtQuick 2.0
import QtGraphicalEffects 1.0
Page {
SilicaFlickable {
Item {
PageHeader { title: qsTr("Semi-transparent Rect") }
Rectangle {
color: "red"
x: 100; y: 150; radius: 15
width: 300; height: width/2
border { color: "yellow"; width: 15 }
Rectangle {
layer.enabled: true
color: "green"; opacity: 0.5
x: 150; y: 200; radius: 15
border { color: "blue"; width: 15 }
FastBlur {
radius: 5
source: greenBox
anchors.fill: greenBox
