Bluetooth visibility timer error
BUILD ID = OS VERSION (Settings > About product): 4.1.0.24 0.2.2.43
HARDWARE (XA2, X10, X10 II, …): Xperia X F5121
UI LANGUAGE: English ( same result : Russian, Hungarian )
DESCRIPTION: After phone restarting, I turned on the bluetooth and I set the visibility time to three minutes.
When the timer expired, I turned off the bluetooth adapter. A few minutes later, I restart the bluetooth. The visibility timer was released, but it didn’t expire, and no way to restart. It worked again after reboot, but only once.
  1. Bluetooth on
  2. Visibility timer on (set up 3 or 15 minutes or On)
  3. After the timer expired ( or set visibility Off ), switch bluetooth off
  4. Few minutes later switch bluetooth on again
  5. Visibility timer not started again.
  6. After reboot, the whole thing started all over again.
ACTUAL RESULT: The visibility timer won’t start again.
