On the Jolla Phone 2026 I have the problem that I am hardly able to search for new devices. I managed to search for new devices twice, pulling down the Bluetooth menu and selecting “Search for devices“. Then I saw a loading bar and a lot of devices around including my headphones.
BUT I was able only twice to see this bar and the not connected devices. Right now a connection to new devices is not possible.
Hi! Have you tried to toggle the bluetooth OFF/ON? If that didn’t help then from settings at the bottom you can find section “Utilities”. From there you can restart the bluetooth. Hopefully one of these helps in your case
Is AppSupport Bluetooth(beta) app still needed in version 5.2.0.22 on C2? Or are the capabilities included in that version? My phone needs an occational reboot to find bluetooth after version upgrade.
Uninstalling AppSupport Bluetooth Beta fixes the problem not completely. When the app is uninstalled I can search for Bluetooth devices and connect to my headphones without any problems.
But without the app Garmin Connect (Android app) moans that bluetooth is deactivated and a connection the watch isn’t possible anymore.
With the app installed Garmin Connect works fine but the headphones are not connecting anymore….(sic)
Same for my J2 5.2.0.22, uninstalling Bluetooth Beta AppSupport did the trick . I instantly retrieved pairing search, connectivity and stability on Bluetooth
