REPRODUCIBILITY: yes
OS VERSION: 5.2.0.17
HARDWARE: JP2026
UI LANGUAGE: French
REGRESSION: unknown
When Appsupport is enable, after disabling bluetooth and reenabling it, scan for bluetooth device does not work any longer. If Appsupport is stopped, it works again.
AppSupport Bluetooth installed
Appsupport launched
turn bluetooth off
turn bluetoot on
try to scan devices in Settings > bluetooth
Scan started
Nothing happens
If AppSupport is stopped and restarted, bluetooth stopped and started, scan works again.
If AppSupport Bluetooth is uninstalled, it works again.
I can’t reproduce this behaviour myself. I tested it just now following your steps, but I also always disable bluetooth among other things at night, without stopping AAS, and have never run into this issue before.
I have the same problem and have to stop AAS and toggle Bluetooth off and on again almost every day to reconnect my watch with Amazfish. I suspect Ghoelian hasn’t installed “AppSupport Bluetooth (beta)”.
With Amazfish the problem is when it’s paired with ZEPP or other app in AAS then it will not be found in BT scan.
In ZEPP you can disable the device and then you can access via native BT…
