REPRODUCIBILITY: 100%
OS VERSION: 4.5.0.19
HARDWARE: Sony Xperia 10II - Dual SIM
UI LANGUAGE: RU
REGRESSION: yes
when I connect bluetooth headset, sailfish always use microphone from phone.
but usb-microphone is working
I try few devices with different profiles AirPods, JBL TUNE500 and 2 nonames. all headset work correct with another phone and pc (debian)
connect some headset with microphone to phone
try use microphone (make call, use recorder, etc)
check used micro:
“pactl list short sources” in terminal
try check available sources after 10-15 minutes: bluetooth sources not in list, but headset not disconnected
talk via headset microphone
headset micro not working
i use patchmanager, but I try remove all pathes for test.
no
I can reproduce on my X10 III too.
My bose Bluetooth headset is working as expected on my 10ii. There must be something special about your situation.
Added to internal tracker
any ideas about special about? maybe I need post some logs? idk, what needed
Does the headset still work for media when the mic isn’t operating as expected for calls? I ask because I’m seeing an issue somewhat similar with my car where the HFP profile drops so calls go thru the handset but the A2DP seems to still be active.
Maybe you find something useful here for investigation?
headset as audio output work correct, but i doesn’t try it more than few minutes
Maybe it’s the same cause that makes the microphone in my car’s hands free system (VW) not working anymore?
Xperia 10 II, Android 12, SFOS 4.5.0.18.
i think ur car’s hands free recognized as bluetooth headset (w/ small profiles differences), but this is similar bugs
vanre
8 May 2024 06:47
11
The Bluetooth mic isn’t switching on the your Sailfish OS device despite removing patches. They’ve tried troubleshooting but might need to reach out for support. However, you can check your mic in the Check Mic Online - Microphone Test online tool so that you can make sure your device is okay
TRUST INDEX
Is webcammictest.io legit? This website has a pretty low score, which means caution is advised.
Domain Creation Date
Saturday 27th, January 2024 12:00 am
Domain Blacklist Status
Not detected by any blacklist engine
Proximity to Suspicious Websites
33/100
vanre
8 May 2024 07:32
13
I think it’s a good tool and I am using it since 2 months and i didn’t find any issue. The only thing is it’s new website.
i’m use default recorder and second phone (make call and test)
I think, this is most correct way, instead some web site
vanre
8 May 2024 07:47
15
Yes i agree with you though
