REPRODUCIBILITY: Always
OS VERSION: 5.0.0.77 UPDATE with 50.2.0.18
HARDWARE:Jolla C2
UI LANGUAGE: French
REGRESSION: No
I use my phone with bluetooth and a Toyota Yaris car (HSD from 2012, old multimedia system).
I have : SPP, A2DP, AVRCP, PAN, HFP, PBAP, MAP in bluetooth parameters.
I can pair my phone, and put it in “Car Kit” mode.
The first time I pair it, I can listen to music, at last one time. No issue for this then.
Issue comes with afterward connections to car.
Then :
If I set option to “always authorize connexions from this device”, then the next time I’m connected to my phone, music is coming from phone and not car speakers
Before 5.2.0.18 :
If I do not set this option it will ask every time before connecting, it may ask for A2DP (then AVRCP, always in this order) or HFP (then PBAP, always in this order). A2DP is for music as I understand, HFP for phone calls
If I begin with A2DP and validate connections (A2DP then AVRCP), then I validate HFP (then PBAP), then I can listen to music and control it.
If I begin with HFP (then PBAP) and validate connections, then I validate A2DP (then AVRCP), then I have no music, it comes from my phone
After 5.2.0.18 it will route sound through speakers even if HFP is connected first manually
I need to have paired my phone to my car to have the issue, and connect it obviously
Enable Bluetooth. Pair with the car.
Disconnect bluetooth, maybe restart phone
Connect to the car, either automatic (“always authorize connections from this devine”) or connect HFP first
Open any media file, whatever the application
Sound should come from my car speakers
Sound comes from my phone
I use stock applications, it won’t work either with media application from sailfish store
I can confirm the same behaviour on my 2018 Subaru Outback infotainment system (Fujitsu Ten).
When I pair the phone with the car audio system for the first time, everything works as expected. However, I can’t manually switch the audio output. For example, I’d like to temporarily switch playback to the Jolla Phone’s speakers and then switch it back to the car’s Bluetooth audio output, but that doesn’t seem to be possible from the user interface. I understand this can be done via the terminal, but that isn’t a practical solution for everyday use.
Another issue is that after I turn the car off and then start it again, the phone reconnects to Bluetooth automatically, but the music no longer plays through the car audio system. Instead, the audio comes from the phone’s speakers. I understand that the audio sink can be switched back via the terminal, but again, that’s not something an ordinary user should have to do every time.
Tested on a new Jolla Phone 2026.
Could somebody shed some light on this issue? Is there perhaps an app that provides a user interface for controlling PulseAudio, such as selecting the active audio output (sink), instead of having to use terminal commands?
I have found similar symptom when playing with BT headsets. Usually cones to headset, but sometimes when switching to an other headset , starts playing via speakers.
Tested one USB-c to 3.5mm adapter and no sound. Installed audio selector. the phone correctly said USB-c audio when adapter plugged in , but played via speaker. Reboot and test wih norma BT earbug , worked ok. Plugged in rhe adapter and , yes the audio was at headset. So there is a kind of glitch , output is detected to be connected and said to be correct/ the one selected but for some reason audio goes to wrong sink.
I’d treat this as a Bluetooth profile order issue, not as a failed pairing.
From your description, A2DP/AVRCP works if it connects first, but if HFP/PBAP connects first, media stays on the phone. That sounds like the car and phone are both paired, but Sailfish is not moving the media route to the car after the handsfree profile is already active.
For testing, I would avoid “always authorize” for now and connect manually in the order that works: A2DP/AVRCP first, then HFP/PBAP. Also delete the Toyota from the phone and delete the phone from the Toyota, then pair fresh with only this phone saved in the car, just to rule out an old car-side Bluetooth profile.
It seems it’s basically the same as before, except it connects to A2DP and AVRCP. So I am asked for HFP and if I accept, it stops music and I can launch it again.
If I chose to trust HFP (and auto connect this way), then I cannot listen to music.
This may be related to an A2DP audio routing issue I investigated on the Jolla Phone 2026.
In my case, Bluetooth reconnects successfully, but OHM fails to activate the A2DP audio route, leaving media playback on the phone speaker.
I’ve published an experimental fix for Sailfish OS 5.2.0.20. I haven’t tested it with car audio systems yet, so I cannot confirm whether it also resolves the HFP/A2DP interaction described here.
I have always opposite behavior. I have all that media sound, but no calls possible. I can accept call by car wheel, but not use car speacers and microphone to speak.
Thanks. I tried the patch (for 5.2.0.22) but for my case it did not change the issue. Maybe it improved call (HFP) over car speaker (with which I had sometimes issues) but as I don’t use this often, I can’t really test for now. I have no regression though.
Like you, if I disable "always authorize connections from this device”, then music comes from my car (rather than my phone). But unlike you, whatever I validate first/last makes no difference, from some brief tests anyway.
Thanks, Okerampa and chr1s, for testing and sharing the details. So far, I’ve tested the fix with Bluetooth headphones. I’ll try to reproduce the issue in our Ford when I get a chance, comparing automatic reconnection with manually confirming A2DP and HFP.
Okerampa’s test shows that the patch didn’t fix media routing in his car. Turning off “always authorize” helped in both setups, though the order of confirmation only seemed to matter in Okerampa’s case. The symptom is similar to what I saw with headphones, and I’m curious whether the Ford shows the same behavior.
I retried and made some tests since 5.2.0.18 and since then, at least with your patch but I can retry without, I can connect manually to HFP (validate hfp) first, then A2DP and I have audio on car speaker.
However, always authorize still always route A2DP through phone speakers. I will edit the report. It’s like Chr1s for me now. It wasn’t the case before 5.0.2.18.
