I think a din´t make any mistake… but look what it says when i launch it… /tmp/tmp.srukKv: line 22: syntax error: unexpected "("
Do you want to always run the latest version of hosty? (recommended) y/n
y
Installing hosty…
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 1277 100 1277 0 0 3659 0 --:–:-- --:–:-- --:–:-- 3659
Fixing permissions…
Checking optional dependencies…
Do you want to automatically update your hosts file with latest ads list? (recommended) y/n
n
execution permissions aren’t granted and thus defender.py cannot call wc -l (but it’s possible to rewrite this in Python).
there are a few files that aren’t made visible within the sailjail: /etc/hosts.editable is missing, the browser cookie files is missing too, causing the code to fall back to an older filepath which isn’t used anymore, etc. (I think /etc/defender.conf is missing, too)
BUT
in defender, the actual engine is separate from the GUI.
so you can manually edit / fetch from backup a copy of .config/harbour-defender/defender.conf (warning, it will be overwritten on defender’s startup as it can’t read the list of sources - presumably from /etc/defender.conf? I haven’t checked that). then either run systemctl status harbour-defender.service (or touch ~/.config/harbour-defender/update to use the .path automatic trigger)
I tried a bit. At least I found a workaround, but all engine should be written again. It takes too much time to update the host file and all process is very heavy.
The general instructions are on the github project. I used what’s now called “option 3” since the docker options weren’t a thing when I first generated my blocklist.
Since pmos is pretty much alpine linux, the only hiccups are making sure that you’ve got the python requirements met. You might need to google how to get pip3 installed on pmos/alpine. IIRC, this wasn’t too much of a hassle. I think I’ve saved a shell script somewhere if things go pear shaped.
Once all that is working, the “Common Steps . . .” section is all you need to do to generate the specific list you need for your purposes.
It’s scaring me to download and run a foreign script as root on my phone. So even if hosty doesn’t do anything wrong, we never know what’s happening tomorrow.
Running hosty as a cron job as root gives the owner of the repository access to all of your data and your system. It will be easy for them to install a backdoor without any sign to the user of the phone. So I would comment to not deploy hosty without supervision.
As far as I understand hosty just updates /etc/hosts. Wouldn’t it be simple to download hosty’s data and create your own script, or even analyse, verify and use hosty’s script statically?
It is easy!
Just choose your StevenBlack list combination (or any list of your choice) and run a cron job on the below. devel-su curl https://raw.githubusercontent.com/StevenBlack/hosts/master/alternates/gambling-social/hosts -o /etc/hosts
Of course change the url to your prefered combo.
