Best way to go forward for a new Sailfish OS/Jolla phone user
Received my new Jolla phone 2026 with Inary Blue TOH.
Before adding all google apps again to get the desired app functionalities again, as I want to use as minimal or no Google at all, I could use some best practice how to go forward. I read about Chum and OpenRepo a bit, but am not sure how trusted the apps are in there.
I want to stay as native as possible instead of using Android apps and Google apps. So I would appreciate some advice for apps to choose and suggestions for better apps than chosen below by me.
In short, my most important functions are:
  • making and receiving phone calls (native possible of course)
  • importing contacts from my Android phone (native persons app succeeded)
  • ASN bank banking app (currently Android app from aura store and I think there is no alternative)
  • OTP application (currently using FreeOTP from f-droid)
  • password manager (none yet, used keepass and bitwarden local on Android phone)
  • Signal (from Aurora store)
  • Whatsapp (from Aurora store)
  • mail (native default installed mail app)
  • customer shop card storage app (digital QR/barcode of customer cards from shops)
  • calendar (native app synced with my nextcloud agenda)
  • Komoot app (trips and hiking trails)
  • Navigation (native Pure Maps)
  • postnl app (post delivery status app from aurora store)
  • KopieID (dutch id card photo app for safe sharing with organizations)
  • Garmin connect (running app for syncing Garmin watch)
  • Menzis app (dutch health assurance company)
  • Nefit easy (heating app for central heating boiler)
  • home assistant app
  • Anker Eufy robotic vac app
Thanks in advance for any kind suggestions and support given
For Bitwarden there’s BitSailor made by me. The Jolla Store version is a bit too old, but if you want to avoid OpenRepos, you can try it first. Otherwise wait until Jolla approves the updated version or get it from OpenRepos.
Have a look at the thread: new jolla phone and new users.
Thank you for your quick reply. Is it possible to connect this client to a self hosted bitwarden server?
I’m gonna start from here, since I believe the previous ones were sorted out:
No bank apps on SFOS yet afaik, someone correct me if I’m wrong
SailOTP if you want to use the official store (Harbour). It doesn’t encrypt your secrets locally (assumes that you encrypted the device yourself when you set up the device, so the secrets are encrypted along with the rest of the file system), only the backups. If encrypting your secrets is important, try out Foilauth. Also, unlike SailOTP, Foilauth doesn’t use sailjail (the permission system) - you might want to keep that in mind as well. Also, also, none of them supports importing your secrets from other apps afaik. I don’t know how FreeOTP does, but Aegis (the one I used before) allows you to scan the secrets as QR Codes one by one as an alternative to exporting the files.
You’re in luck here, both options are sorted:
  • OwnKeepass - for KeePass
  • Sailwarden or Bitsailor (from Harbour) - for Bitwarden
Try Whisperfish. Mind that it doesn’t support importing backups yet.
Take in mind the fact that WhatsApp forbids the use of third party clients. To circumvent any possible bans, any client basically uses the web version of WhatsApp to function. There are a few options out there:
  • Native clients: whatsapp and WhatsUp
  • Use WhatsApp with Beeper and use it via a Matrix app (there’s Sailtrix and Xmatic)
  • Use an XMPP service with it such as Hot-Chilli, then log in to your XMPP account in the settings - this way, you could use your default Messages app for WhatsApp, albeit with plenty of limitations - for example there are no group chats this way (also make sure to configure telepathy-gabble-plus and share-plugin-telepathy if you go this route); or you can use Livewire.
Be careful to also open the official WhatsApp app wherever you have it installed at least once every 14 days, otherwise you’ll be logged out of any of these clients.
That’s it. The one in Harbour. Or you can try out SF-Mail.
Sailcards or Barwal
I don’t know of any other app than the native one. Log in to your Nextcloud account in settings
Maybe someone else can help here. I don’t use any such thing.
Yep, seems like it’s the best native option, or use the Organic Maps port.
I don’t know about any of the other options.
Yes, both official and vaultwarden are supported.
Some apps where already mentioned. I can strongly recommend
  • Foil Auth for OTP
  • ownKeepass
  • Whisperfish (2nd. Device, you still need to have Signal around on the same or some other device)
  • Many Apps for cards do nothing a picture or a pfd won’t do
  • Pure Maps is good and OSMScout also works fine as an alternative. I used Here Wego from Aurora for some time but there were problems with Android based navigation when the Jolla 2026 came out. I do not know whether that has been fixed yet. But I do not miss Here Wego actually. Keep GPSInfo around anyway just in case you run into trouble getting a fix or loose your position.
I have to sort all your suggestions out, but am happy with your kind support. At firs it seems that, in the Jolla Store, the following apps don’t seem there. OwnKeepass, Sailcards, Barwall
It might take some time to sort all out, but I’ll update my findings and results here. Thank you so far.
As others have pointed out some great apps, I won’t repeat all of them. But here’s my thoughts:
Have you tried integrating this to Home Assistant and not use a separate app? This integration could work: Nexity Eugénie - Home Assistant
There’s an excellent native app (Helmsman) made by @pauligrinder. This, however is in no store yet, so needs a manual download (and update from Github): Releases · Pauligrinder/HomeAssistant · GitHub
I’ve been using both OSM Scout (Harbour) and testing the Organic Maps. It’s still in a pre-release status, but can be downloaded here: Releases · klahr/organicmaps-sailfish · GitHub
Helmsman is in openrepos, alread b.t.w.
Thanks for the mention guys, and yup, Helmsman is on Openrepos, but it’s not up to date at the moment because OpenRepos is in read only mode while they investigate what needs to be done about the recent CVE’s. I’ll update it when it’s possible again, but in the meantime the most recent version can be downloaded from github.
True, my bad. Been downloading it from Github, so forgot that it was there already.
For password manager I highly suggest Bitsailor (=Bitwarden)!
