Sony Xperia XA2, SailfishOS 3.4.0.24
It’s very cold around here atm, 10 to 20 degrees Celsius below. When I move around outside, and my phone is in a cold jacket pocket, the battery goes flat very fast.
But it comes back up when it gets warm again; however, the battery percentage displayed does not come back up. This can lead to a situation where the OS shuts down because it thinks that the battery is at 0%. If I then warm the phone up again, I still cannot start it because of that.
Only when I connect the charger, it jumps to a much higher percentage almost immediately, and I can boot again.
This has happened many times now; and I don’t even know if this is a SailfishOS or a hard/firmware problem.
I seem to remember from years back that Android used to have the same problem (on another device), but it got fixed in later versions (on yet another device).
What can be done?
The journal right now shows:
journalctl | grep -i batt | grep -vi batteryoverlay
Jan 17 19:30:26 XperiaXA2-DualSIM kernel: FG: fg_gen3_probe: battery SOC:1 voltage: 3831289uV temp: 330 id: 0KOhms
Jan 17 19:30:26 XperiaXA2-DualSIM kernel: FG: fg_get_time_to_full_locked: battery profile is not loaded
Jan 17 19:30:26 XperiaXA2-DualSIM kernel: of_batterydata_get_best_profile: 1309-2682 found
Jan 17 19:30:31 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): charger_type: none -> usb
Jan 17 19:30:31 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): charger_state: undefined -> on
Jan 17 19:30:31 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_state: unknown -> charging
Jan 17 19:30:31 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_status: undefined -> ok
Jan 17 19:30:31 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_level : -1 -> 1
Jan 17 19:30:59 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_level : 1 -> 2
Jan 17 19:31:15 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_level : 2 -> 4
Jan 17 19:31:48 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_level : 4 -> 5
Jan 17 19:31:56 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_level : 5 -> 6
Jan 17 19:32:04 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_level : 6 -> 7
Jan 17 19:32:21 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_level : 7 -> 8
Jan 17 19:32:37 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_level : 8 -> 9
Jan 17 19:32:53 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_level : 9 -> 10
Jan 17 19:33:08 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_level : 10 -> 11
Jan 17 19:33:26 XperiaXA2-DualSIM mce[2879]: modules/battery-udev.c: mcebat_update(): battery_level : 11 -> 12
Jan 17 19:33:57 XperiaXA2-DualSIM kernel: QPNP SMB2 probed successfully usb:present=1 type=0 batt:present = 1 health = 1 charge = 3
Jan 17 19:33:57 XperiaXA2-DualSIM kernel: FG: fg_gen3_probe: battery SOC:14 voltage: 3856679uV temp: 320 id: 0KOhms
Jan 17 19:33:57 XperiaXA2-DualSIM kernel: FG: fg_get_time_to_full_locked: battery profile is not loaded
Jan 17 19:33:57 XperiaXA2-DualSIM kernel: of_batterydata_get_best_profile: 1309-2682 found
Jan 17 19:34:02 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): charger_type: none -> usb
Jan 17 19:34:02 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): charger_state: undefined -> on
Jan 17 19:34:02 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_state: unknown -> charging
Jan 17 19:34:02 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_status: undefined -> ok
Jan 17 19:34:02 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : -1 -> 14
Jan 17 19:34:03 XperiaXA2-DualSIM systemd[1]: Starting Battery Buddy file permission daemon...
Jan 17 19:34:03 XperiaXA2-DualSIM unknown: type=1130 audit(1610904843.286:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=harbour-batterybuddy-oneshot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 19:34:03 XperiaXA2-DualSIM systemd[1]: Started Battery Buddy file permission daemon.
Jan 17 19:34:03 XperiaXA2-DualSIM audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=harbour-batterybuddy-oneshot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 19:34:08 XperiaXA2-DualSIM systemd[4976]: Started Battery Buddy background daemon.
Jan 17 19:34:14 XperiaXA2-DualSIM healthd: BatteryFullChargePath not found
Jan 17 19:34:14 XperiaXA2-DualSIM healthd: BatteryCycleCountPath not found
Jan 17 19:34:14 XperiaXA2-DualSIM healthd: battery l=14 v=3786 t=32.0 h=2 st=2 c=342 chg=u
Jan 17 19:34:18 XperiaXA2-DualSIM healthd: battery l=14 v=3787 t=32.0 h=2 st=2 c=310 chg=u
Jan 17 19:34:21 XperiaXA2-DualSIM healthd: battery l=14 v=3774 t=32.0 h=2 st=2 c=401 chg=u
Jan 17 19:34:51 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 14 -> 15
Jan 17 19:35:07 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 15 -> 16
Jan 17 19:35:14 XperiaXA2-DualSIM healthd: battery l=17 v=3861 t=33.0 h=2 st=2 c=-219 chg=u
Jan 17 19:35:21 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 16 -> 17
Jan 17 19:35:40 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 17 -> 18
Jan 17 19:35:49 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 18 -> 19
Jan 17 19:35:56 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 19 -> 20
Jan 17 19:36:12 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 20 -> 21
Jan 17 19:36:14 XperiaXA2-DualSIM healthd: battery l=21 v=3892 t=33.0 h=2 st=2 c=-410 chg=u
Jan 17 19:36:29 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 21 -> 22
Jan 17 19:36:45 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 22 -> 23
Jan 17 19:37:01 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 23 -> 24
Jan 17 19:37:14 XperiaXA2-DualSIM healthd: battery l=25 v=3890 t=32.0 h=2 st=2 c=-366 chg=u
Jan 17 19:37:14 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 24 -> 25
Jan 17 19:37:34 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 25 -> 26
Jan 17 19:37:44 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 26 -> 27
Jan 17 19:38:06 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 27 -> 28
Jan 17 19:38:14 XperiaXA2-DualSIM healthd: battery l=29 v=3857 t=32.0 h=2 st=2 c=-86 chg=u
Jan 17 19:38:27 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 28 -> 29
Jan 17 19:38:36 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 29 -> 30
Jan 17 19:38:59 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 30 -> 31
Jan 17 19:39:14 XperiaXA2-DualSIM healthd: battery l=32 v=3903 t=32.0 h=2 st=2 c=-451 chg=u
Jan 17 19:39:16 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 31 -> 33
Jan 17 19:39:32 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 33 -> 34
Jan 17 19:39:48 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 34 -> 35
Jan 17 19:40:05 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 35 -> 36
Jan 17 19:40:14 XperiaXA2-DualSIM healthd: battery l=36 v=3840 t=31.0 h=2 st=2 c=81 chg=u
Jan 17 19:40:22 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 36 -> 37
Jan 17 19:40:39 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 37 -> 38
Jan 17 19:40:55 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 38 -> 39
Jan 17 19:41:09 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 39 -> 40
Jan 17 19:41:14 XperiaXA2-DualSIM healthd: battery l=40 v=3871 t=31.0 h=2 st=2 c=-184 chg=u
Jan 17 19:41:27 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 40 -> 41
Jan 17 19:41:36 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 41 -> 42
Jan 17 19:42:00 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 42 -> 43
Jan 17 19:42:02 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 43 -> 44
Jan 17 19:42:14 XperiaXA2-DualSIM healthd: battery l=44 v=3895 t=31.0 h=2 st=2 c=-358 chg=u
Jan 17 19:42:29 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 44 -> 45
Jan 17 19:42:49 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 45 -> 47
Jan 17 19:43:14 XperiaXA2-DualSIM healthd: battery l=48 v=3909 t=31.0 h=2 st=2 c=-429 chg=u
Jan 17 19:43:26 XperiaXA2-DualSIM mce[2866]: modules/battery-udev.c: mcebat_update(): battery_level : 47 -> 48
Jan 17 19:44:14 XperiaXA2-DualSIM healthd: battery l=48 v=3890 t=31.0 h=2 st=2 c=-265 chg=u
Jan 17 19:45:14 XperiaXA2-DualSIM healthd: battery l=48 v=3905 t=31.0 h=2 st=2 c=-393 chg=u
