But looking again at your graph: the average consumption is 85mAh.
The XA2 battery is 3200mAh. Let’s say 3000.
3000/85 = 35 hours. Let’s say 25 hours, not to ruin the battery by emptying it too much.
Does your phone hold so long with this setup?
If not, is the battery perhaps becoming to old?
Since you don’t seem to have the issue, could you please tell me how frequent you see lines added to the ofono logs while the phone is not in use?
With 4G enabled, I have a few dozens every minute, while with 2G, it I see 10-20 minutes between 2 log lines.
I would have with pleasure but I just broke my XA2 2 days ago. I’ll try to think of it next week when back home on my wive’s one.
Do you see that with journalctl?
Thanks, but that won’t be necessary for now since I made some progress:
I was able to reduce battery drain by about 2x by resetting the APN and disabling the Android Support (not sure if both of them were necessary, but they seemed required to reduce the log output of ofono).
(I’m going to have to figure out whether I badly configured the APN, since the default is not the good one.)
I’ll continue my investigation as I’m seeing some wlan activity with lots of suspends and resumes, so I might ask you for some logs at some point to compare.
