I have strange behavior on my XA2 with Battery Buddy. I have a high CPU Load when the phone should idle around. When I plug in the USB cable the utilization drops suddenly and comes back after I disconnect the phone. Can I somehow remove the log of the App to get a better overview?
I have no immediate guess what causes that… I suggest you try running htop and un/plugging the charger, perhaps with roop privileges, and see what it tells you… Battery Buddy logs won’t help deducing the cause, I’m afraid.
OK, thanks. FYI and OT - Here is what i found: more strange behavior
I logged in via wifi and changed the user to root. Had a very short look on top - haven’t seen nothing suspicious and installed powertop additionally. Then I just wanted to connect the phone to the cable and the pop up menu for media transfer vs. just charging vs. developer flickered 3 or 4 times after i was able to select just charging mode. I checked top and powertop and wanted to compare for a first try what is happening when I disconnect the phone. Again, nothing what directly seems the reason for a high load. And here is whats new. After I disconnected the phone I realized that the CPU utilization stays low. So I think this flickering caused something.
I know there is a bug with voicecall ui and I realized, that this high usage on my phone somehow correlates everytime I miss a call. But this charging thing is new.
Linking to a possibly related observation in a different thread:
Also, I think I saw this behaviour when chasing the “phone drains battery when in flight mode” problem (this still happens occasionally in 4.4.0.58 on Xperia X).
It’s rather trivial to add the value, and it’s only as reliable as the firmware/hardware reports it. (What counts as a cycle? From 20% to 60%? Charging so that percentage increases by +50%? We can’t know.) There is some use to it still; bugger number means more wear, if nothing else.
The icon behavior is controlled by the OS, and I find it logical to have the cord visible, as the charger is connected. The bolt shows always, I think.
I do agree with you… that it´s not very clear what a cycle is…
I actually try to charge it from 30 to 75… so… i could never be considered a full cycle… or yes… Who knows !!!
Thinkpad laptops do have an battery app where you can count cycles, but i ´ve never looked into what a cycle is considered. It´s just a “funny” info.
One cycle is a 100% recharge, i.e. in case of a 4500 mAh battery it means feeding it with 4500 mAh. But not necessarily at once, it can be done in parts. If you recharge by 50% (2250 mAh) then it takes doing it twice for the cycle counter to increase by 1 cycle. In case of recharging by 20% (900 mAh) it takes doing it five times for the cycle counter to increase by 1, and so on. Any combinations are possible (e.g. 20% + 40% + 17% + 23%). It simply counts and remembers the mAh’s it gets from the charger and increases the cycle counter by one cycle only when that value sums up to 100% of the battery capacity. At this point it increases the cycle counter and then it starts counting mAh’s anew. It’s very simple and there’s absolutely nothing mysterious about it…
Battery Buddy stopped showing battery health on my 10 III. Now it always reports ‘Unknown’. I’m not sure when it happened, probably after the last update…
EDIT: Oops, it turns out that it wasn’t the latest version. Updating from 4.2.3-1 to 4.2.5-1 fixed it.
Worth considering for future versions of Battery Buddy is a different approach to battery saving that e.g. iOS uses. Battery is always charged to 100%, but the current is controlled so that charging ends at the desired time, e.g. very shortly before the user usually wakes up. The program calculates how much time is left until the desired hour and reduces the current automatically so that charging is slow enough to reach 100% only at that time. Of course, this takes monitoring the current that the device consumes in order to increase or decrease the input current so that the RESULTING current (delivered - consumed) equals what’s needed to get the required speed of charging…
Of course in iOS it is quite sophisticated, including learning of user’s habits so that it can be as automatic as possible, but I would love it even in a much simpler form, e.g. where I manually set the destination time and the program would modulate the current / charging speed so that charging reaches 100% at the chosen time (of course, within available current ranges).
This way when I wake up, or when I leave home, I would always have 100% of battery freshly charged, whereas now charging usually ends much sooner and the battery manages to discharge quite noticeably before I even touch it… I guess it would be much more useful, and much more practical when it comes to battery saving too, if such a function allowed me to finish charging as LATE as possible, as this way I would then end the day with MORE power left in the battery, quite possibly enough not to charge it until the next day. And that would be a true battery saving.
@direc85 I’ve just noticed that the Start button to manually start the service depends on the state of the “Start background service at startup” setting on the Settings page. If the setting to automatically start the service at boot is disabled, the “Start” button doesn’t work (even though it looks like an active button and is ‘clickable’ but it has no effect). So in order to manually start the service one has to temporarily enable that setting.
Another thing that I’ve been forgetting to report for a long time is a small glitch in Polish translation: on the main page both “State” and “Health” are translated in Polish as “Stan” (so there are two rows called “Stan”). I’d suggest to change it so that “State” is translated as “Status” and “Health” is either just “Stan” as it is now, or even better “Stan baterii”.
And while we’re at translation, “Maximum Charge Current” is not yet translated. Its Polish translation is: “Maksymalny prąd ładowania”. It would be also great if “Start background service at startup” could be changed (in order to avoid the “uruchom” word being repeated) from “Uruchom proces w tle podczas uruchomienia” to “Uruchom proces w tle podczas startu urządzenia”.
There’s now a new Battery Buddy release available, with a patch release too, to be exact. Battery Buddy 4.3.0 now supports PineTab Pro due to the work done by @nephros! 4.3.1 updates Polish translation as suggested by @wetab73. The source code repository is now up-to-date again (whoops).
I couldn’t replicate the behavior of the start button you described, so debugging that is quite hard… Does someone else have the problem? The start/stop buttons should be independent of the auto-start status, and if they are not, it’s a bug indeed.
I’m not sure what I did, but I guess it took either closing and reopening the application after switching that setting off, or rebooting the device with that setting switched off and then opening the application. Either way, now it is persistent, i.e. the Start button only works if that setting is enabled. Also after updating to 4.3.0.
Thank you for updating the translation! Just one remark, can you please also change the “State” string (currently translated as “Stan”) to “Status”?
Updated to version 4.3.1-1 and in addition to the aforementioned problem with the Start button now also the Max charging current setting stopped working. Despite setting it to e.g. 500 mA, the charging current is still 1400 mA. It used to work OK in previous versions. Actually, I’m not sure if anything works but the GUI. What is the name of the background service so that I can check if it is running at all?
Edit: I downgraded to version 4.2.5-1 and now Max charging current setting works OK again. So there must be something wrong with it in the latest version(s). Sadly, the Start button still only works when the “Start background service at startup” setting is enabled.
