REPRODUCIBILITY: 100%
OS VERSION: 4.4.0.68
HARDWARE: Xperia 10 II
UI LANGUAGE: en
REGRESSION:
Backspace deletes two characters in Twitter web app.
A Twitter account
- Go to Twitter web page
- Start typing a tweet
- Press backspace to delete last character
Last character is deleted
The last two characters are deleted
PM with swipe right patch enabled.
It seems a bug of browser history switch patch, if you disable it, it works fine
I don’t have that patch installed. Out of curiosity, what does it do and how do you recon it affects input behavior?
I thought that you have browser history switch patch installed, what is the patch are you referring in MODIFICATIONS?
In my case, I have browser history switch patch installed, if it is enabled I have exactly the same issue as you, if I disable it, backspace deletes only one character, so it works fine.
Unfortunately my phone is in a unusable state right now, so I cannot check the full patch name, but its functionality is to try to fix right hand swipe, that sometimes fails due to bad responsiveness/bad calibration of boundary values.
