i have a question about backporting and putting sfos on xperia 10 ii. https://sailfishos.org/wiki/Sailfish_X_Xperia_Android_10_Build_and_Flash says audio during calls doesn’t work, but it can be backported from https://git.sailfishos.org/mer-core/ohm/merge_requests/15 and https://git.sailfishos.org/mer-core/ohm-plugins-misc/merge_requests/35 although it seems those merge requests had been already made. so then i don’t need to backport anymore and if i need to, how can i backport this?
Just check that those commits are done in the branch you are building from, then you shouldn’t have an issue and indeed the wiki would be outdated.
