On the new Jolla Phone screenshots are taken by pressing both volume buttons simultaneously.
The screenshot itself works, but the volume is also changed every time I take a screenshot.
This feels confusing and makes the shortcut less reliable to use. It would be great if the system could detect the screenshot shortcut before applying the individual volume button actions, or provide an alternative way to take screenshots.
Ah, you mean the app launcher, which you open with a swipe from the bottom edge, and where you have all the app icons and can sort them into folders? Yep, you’re right, it isn’t possible to use the top menu in there.
As nthh wrote, it is not possible to take screenshot of app launcher screen this way. I do not have any problems to have screenshot even of app launcher screen (using vol up-vol down). I just wanted to point out, that top menu option is not available in that situation.
