Avatars contacts from Nextcloud can't syncing
REPRODUCIBILITY: always
OS VERSION: 5.0.0.55
HARDWARE: xperia 10 ii
UI LANGUAGE: French
REGRESSION: yes
Avatars which are send by Nextcloud instance in the Contacts app are not synced.
The avatars which where in the Contacts list 4.6 are partially deleted.
Contacts in a Nextcloud instance
  1. Contacts in NC with avatars
  2. wait syncing
  3. Contacts in SFOS 5.0.55 are deleted.
Avatars in the Contacts app.
Avatars are usually deleted in the list and in the details personnal informations.
Sometimes, avatars is showed in the list but disappear in the details contact informations.
No
It works in the upload way : if I put a new avatar for a contact in the Contacts app, it will be synced in the contacts of NC.
I’m experiencing the same issues; also some contacts that previously had avatars have now lost them.
Bug always here in 5.0.0.62
