Hello, I would like to know if there exists some macros for the compiler.
Like the following:
aarch64 arm i486
And I would like to know the endianess of the machine architectures. I guess all are little endian?
Is there a macro for 32bit and 64bit and a BYTE_ORDER macro?
Yes, all are little-endian… but you could use the __BYTE_ORDER__ macro for that.
You can use __i386__, __x86_64__ and __aarch64__… or maybe the size of the size type is more relevant for your needs.
nothing SFOS specific about it…
