OSVERSION: 5.0.0.21
HARDWARE: Reeder S19 Max Pro S - s19mps - s19mps - 1.0.0.15 - aarch64
REGRESSION: yes (since: 4.6.0.13 - aarch64)
AppSupport is turned off and disabled to start on boot up, still starts after bootup
Go to settings and stop appsupport
Disable appsupport start up on bootup button
reboot the device
Unlock the device go to settings and check the appsupport status
EXPECTED RESULTS:
The staus of appsupport should be stopped
ACTUAL RESULTS:
The status of appsupport is running
Patchmanager: no
OpenRepos: yes
Chum: yes
Other: none specified
I get the impression that opening the appsupport setting page somehow triggers appsupport to start
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.10+git7
Maybe you could just copy-paste your report as a reply in my thread, and then maybe we could try to delete things here? That would save a round-trip to Jolla staff, who no doubt are pretty busy atm.
