Hey guys,
I have published the first version of a data pass client that can be used with the telekom service to track data usage. It is available here: GitHub - conradhuebler/harbour-datapass: Monitor your Telekom data usage on Sailfish OS even with a rpm package (uploaded from my own tests using sailfish sdk)
Release First Release · conradhuebler/harbour-datapass · GitHub
The code is mainly AI generated
as is the icon
PS:
But I don’t understand why I can lauch the app from the console using
sailfish-qml harbour-datapass
but not from the launcher.
Because the Exec
line in your .desktop file will cause launcher to try to execute a binary called harbour-datapass
which does not exist.
Either write an application which compiles to a binary of that name, or change the Exec
line to:
/usr/bin/invoker --type=silica-qt5 /usr/bin/sailfish-qml harbour-datapass
Yes, indeed. But I went back to
which used to be there before editing.
The AI just replaced the line - (really
). I uploaded the updated package
Is there an important difference if I use the /usr/bin/invoker approach?
AFAIK Sailjail doesn’t use the X-Nemo-Foo
keys.
Using invoker you can specify things like type or single-instance or any of its command line options.
If you don’t need them I guess sailfish-qml is fine.
Meet sailorAI, a LLM Chat App supporting openAI and Gemini (Anthropic is untested). Chat with different models as long there is an API Key, Chat History etc. It is purely Claude driven (Using the Pro Version, there is not API access). No deps, API Calls are done via REST. Code is here: GitHub - conradhuebler/harbour-sailorAI: Native Sailfish LLM Chat App
And I udapted the datapass as well, I suppose both apps can go to the official store …
