REPRODUCIBILITY (% or how often): 100
BUILD ID: 3.4.0.22
HARDWARE (Jolla1, Tablet, XA2,…): Xperia 10 plus
UI LANGUAGE: EN
Overlay application crash the device, like battery overlay or screenshot2, solved by reboot only
Well, not exactly crash, but it seems like the compositor straight out ignores the alpha layer, but it doesn’t block the user input, at least for Tint Overlay.
Luckily the pulley menus give haptic feedback, so closing tintoverlay is not a big problem.
Unfortunately, I already updated and am not able to enter GUI again.
During the update process a message appeared like ‘Something went wrong, please try again later. REBOOT’.
After reboot, I have no GUI (only some kind of flickering white/black a few times).
ssh and devel-su into the phone are working.
Is there a list of potential overlay applications? Any suggestions?
pkcon refresh
-> Fatal error: Medium not attached: plugin:/ssu?repo=adaptation0
version --dup
-> Error: Medium not attached: plugin:/ssu?repo=adaptation0
ssu status
Device registration status: not registered
Device model: Xperia XA2 - Dual SIM (h4113 / h4113)
Device variant: sony-nile
Device UID: …
Release: 3.3.0.16
Domain: sales
Brand: Jolla
EDIT:
I solved it with ‘pkcon update; version --dup’
Now I am back at version 3.3.0.16 and give the upgrade another try.
Update failed.
Reboot and flashing white screen.
“pkcon update” was enough for my XA2+ finished the update and as soon as the required packages installed the screen came up.
