BUILD ID = OS VERSION (Settings > About product): 3.4
HARDWARE (XA2, Xperia 10…): Vollaphone, Fairphone2
UI LANGUAGE: EN
DESCRIPTION: Having tested SSH and rsync, uploading files (and ssh terminal) works fine. But deploying RPM ‘stopped’ working. I have successfully been building for weeks (3 apps added to the Jolla store). It. just. stopped.
- I don’t think you can.
Deploy RPM
bash: sdk-deploy-rpm: command not found
From compile:
sending incremental file list
harbour-beamdimension-0.2-1.armv7hl.rpm
sent 849,857 bytes received 35 bytes 566,594.67 bytes/sec
total size is 849,532 speedup is 1.00
Deploy failed
15:48:39: The process "/home/mwa/.config/SailfishSDK/libsfdk/build-target-tools/Sailfish OS Build Engine/SailfishOS-3.4.0.24-armv7hl/deploy" exited with code 1.
Error while building/deploying project harbour-beamdimension (kit: SailfishOS-3.4.0.24-armv7hl (in Sailfish OS Build Engine))
When executing step "RPM"
15:48:39: Elapsed time: 00:09.
