The bulk of the code is largely copied from an official QML example from QT.
I wanted to play with motion/animation; in this case, a sweeping second hand was my main aim, but there are performance problems with SFOS SDK/Emulator and devices compared to Community QtCreator 5.15.2
I have tried using ITEM, RECTANGLE and IMAGE for the clock hands, there is hardly any performance difference, CPU usage is quite high and causes lagging and stuttering when run on Emulator or mobile device, making the sweeping action more like a fake Rolex, it looks like poop! With or without smoothing and/or antialiasing, it is still jerky on SFOS
High CPU usage
community qtcreator 5.15.2
CPU usage - 1% > 3%
fan is quiet
sailfish qtcreator via emulator (latest)
CPU usage 25% > 45%
fan is racing
SFOS 4.3
CPU usage similar to above on Xperia 10 ii and Jolla1
The code shown below is currently for ‘community QtCreator’ but can easily be changed to run on SFOS SDK;
import QtQml 2.12
import QtQuick 2.2
import QtQuick.Controls 2.12 // Sailfish.Silica 1.0
import QtGraphicalEffects 1.0
Item {
property int hours
property int minutes
property int seconds
function timeChanged() {
var date = new Date;
hours = date.getHours();
minutes = date.getMinutes();
seconds = date.getSeconds()
Timer {
interval: 1000
running: true
repeat: true;
onTriggered: {
clock.timeChanged()
Image {
source: "graphic-clock-face-5.png" // without file extension for sfos
anchors.centerIn: parent
Rectangle {
color: "#66666666"
radius: width/2
width: 412
height: 412
Rectangle {
x: 195
y: 101
width: 10
height: 100
color: "green"
transform: Rotation {
origin.x: 5
origin.y: 99
angle: (clock.hours * 30) + (clock.minutes * 0.5)
Behavior on angle {
SpringAnimation { spring: 2; damping: 0.2; modulus: 360 }
antialiasing: true
Rectangle {
x: 197
y: 52
width: 6
height: 150
color: "blue"
origin.x: 3
origin.y: 148
angle: clock.minutes * 6
Behavior on angle {
antialiasing: true
Rectangle {
x: 199
y: 50
width: 2
height: 150
color: "#00000000"
origin.x: 1
origin.y: 150
angle: clock.seconds * 6
Behavior on angle {
RotationAnimation {
duration: 1000
direction: RotationAnimation.Clockwise
antialiasing: true
Image {
z: 2000
source: "icon-m-sailfish.png" // without file extension for sfos
rotation: -secondRotation.angle
anchors { top: second.top; horizontalCenter: second.horizontalCenter }
sourceSize {
width: 45
height: 45
smooth: true
antialiasing: true
