Android Support Passkey configuration and lock screen
Hi,
it looks like passkeys for the apps could be activated if a android screen lock can be activated.
By the way it is not accepted so passkey could not used so I must login each time in any android app i will use and needs an login.
Is there a solution that androids passkey can be used?
By the way I installed the stuff to use the google play store on my Xperia 10 III.
Not at the moment.
Jolla, need to somehow tell the android subsystem that a lock code is enabled. Since this is a security feature i’m sure it’s not going to be easy to get the subsystem to accept it.
See also Banking Apps with SailfishOS
As far as i am understanding how android works would that be not a simple fix.
Android requires the lock code not for it to have the code but for what that code is used for.
Android uses the password or pin for making a custom userdata encryption in terms of using the hardware keys the boot loader holds secure and adding it ontop of that to then use both to encrypt the Passkeys and other stuff that uses the Android strongbox.
Sailfish os would need to have a Linux managed keystore that the user / malware should not be able to access to act as the strongbox that AAS will use to fix that.
microG supports passkeys now and having usb based FIDO device pass trough support for AAS or NFC (when support for pass trough is ready).
