This happened to me last week on my XA2.
I was unable to delete Android apps and App Support, yet could not start it.
Hereâs all the steps I took, maybe one of them works for you:
I had Patchmanager installed, particularly a patch to have an Android button in my top menu. I deinstalled it all, but to no avail.
Then I tried to free up some space, as people have described App Support re-starting after that. In my case that didnât happen.
A reflashing or factory reset usually solves this problem, but before losing all those apps and settings, I ventured to increase the root volume size, also said to bring App Support back to life, following this guide:
Everything went smoothly (Thank you @olf!), and I went from below 1 GB to 6 GB free space on the root partition (at least 1 - 2 seems to be desirable).
Nice, but no effect on App Support.
Lastly, I backed up my Android data and removed App Support via Terminal the âbrutal wayâ, as described here:
This time App Support was gone for good, and after reinstalling it from the Jolla Store, it worked again!
So I had to delete the Android side, but could at least keep all Sailfish apps and settings.
This might have worked without the root partition meddling, but I included it for transparency.
Good luck!
