Android SDK too old for F-Droid (and most Android apps)
REPRODUCIBILITY: 100%
OS VERSION: 4.6.0.15
HARDWARE: Jolla C (yes, the old Jolla C, not the C2)
UI LANGUAGE: German
REGRESSION: don’t know
I’m trying to install F-Droid from the Jolla Store on my Jolla C (bought recently). However, there is an error message telling that Andorid SDK 24 was needed and my phone had only Android SDK 19. After that, the F-Droid store seems to be installed (according to Jolla Store), but it doesn’t show up on the phone. I can uninstall and reinstall it from the Jolla Store with the same result.
After receiving the Jolla C, I
  1. did a factory reset,
  2. installed all OS updates up to 4.6, and
  3. installed Android AppSupport from the Jolla Store.
See Preconditions and Description above.
I’ve expected that after updating the phone to SFOS 4.6, the AppSupport would be on par with Android 11, i. e. Android SDK 30.
While installing F-Droid, the error message says that my phone is on SDK level 19 and thus F-Droid can’t be installed.
Just installed a few additional basic Jolla apps.
Should you mean Jolla C it means it is not supported anymore.
The answer is forget.
No; the Tablet, Jolla C (1) and Xperia X are stuck on AAS 4.4 - and also out of support on SFOS. These are ancient devices.
Thank’s for the immediate responses. I didn’t expect that Jolla C is stuck on an ancient Android level. I know that support for Jolla C ended with SFOS 4.6 last year. But I really expected that SFOS updates also increase the Android level of AppSupport.
That only happened from new AAS, on the XA2 and onwards.
The Android version is/was clearly documented.
I guess technically the Jolla C is on the licensed Aliendalvik thing, and actual AAS is a better remake which Jolla themselves control fully.
For the old Systems there is F-Droid Legacy. It runs on my Jolla 1 (JP-1301) Phone.
Thank you for the hint, @explit! Is F-Droid Legacy the same as F-Droid Classic?
Now I’ve got F-Droid Classic on the phone, but initially, it couldn’t load any package indexes out-of-the box; the error message is “Error getting index file” – even if I only select the package source “F-Droid Classic”.
This was a problem with the CA trust list, which I could fix by installing the Let’s Encrypt root certificate with the help of Root cert problems on AppSupport 4.4.4 - #2 by ugeuder. Most package sources were usable then, except “F-Droid Archive” (app crashes because archive seems to be to big) and “F-Droid” itself, which uses another root CA (HARICA TLS ECC Root CA 2021). I could have inserted that other root in the same way as with Let’s Encrypt, but I thought, I should get the complete bunch of relevant root certificates at once. Indeed, I found a solution for this: Update root CA certificates for legacy Android AppSupport system - #2 by Chwinterhoch5.
