Android NexPhone
Just AS info. Other Linux phones do that actually
This is no Linux phone β†’ β€œDebian runs as an app with GPU acceleration on top of Android.”
It is just Android.
yes, I see now. but the feature is there :wink: you connect to the display and you have a desktop β€œPC”
You can do that with most modern android smartphone.
USB-C Dock + https://userland.tech/
Is it possible with Jolla C2 to connect via usb-c-dock?
Yes, but the request is to have it native in the JP2 :slight_smile:
I once connected a USB-C dock to my Jolla C2 with a wireless keyboard and mouse, and it worked!
So it should work on the JP2 as well.
This convergence works pretty good already with ubuntu touch on Fairphone 4.
This nex phone is an Android and Win phone, so nothing for me.
But also with external monitor?
yes, nothing for me too. It was just as info, that others trying this convergence mode also. So it looks like people ask for that. I meant, it would be enough for 70% of my tasks to work with phone connected to monitor keyboard an mous…
No external Monitor. But if the Monitor is attached to a computer you can use Screencast | OpenRepos.net β€” Community Repository System.
For screencast you will need additional PC. What I mean, is to use the smartphone in desktop mode instead of PC
on Fairphone 4 with UT, yes. No PC needed. The phone becomes the PC (and some other UT Phones work, too). That’s what I meant with convergence.
