Hello,
I searched the web for a long time to find a way to make my android apps (actually mostly(only) spotify) to make use of the sd card. I found some hacks and sdcard-apps. But, i have no working solution yet. I found announcements, that it should work out of the box with up-to.date Sailfish version. It is very confusing for me if it should work or not with my setup and which of the many solutions i should chose. I made a complete fresh installation of
I have Sailfish X on my Xperia X. Would it be possible to make some instructions on how to use the sd card for android apps for my setup?
Kind Regards
Matt
